Joshdashef Posted March 13, 2019 Report Share Posted March 13, 2019 My two RF P3D4s are getting pretty stinky when I go heavy on them. I've had them for over a year now and I think its time for an upgrade. I want to fit a pair of 15s but I don't think I will be able to until I reorganize my whole trunk and get some more power if not double / more electrical. For now I want to just get a new set of 12s that can fit into my current box with about 1.8 cubes per sub (3.6 net cubes total) tuned to 33/34 hz and a mounting depth of about For reference ill be powering them off a DC 2k at 1 ohms and using two dual 4 ohm subs to get to that nominal load. Should I be looking for lower qts subs? higher power handling (>600 rms and <1000 rms)? lower fs? higher sensitivity (db @ 1w/1m)? higher xmax? Any input would be great Cheers SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
ToNasty Posted March 13, 2019 Report Share Posted March 13, 2019 Sundown sa12s should do great in that size enclosure ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
DiBo Posted March 13, 2019 Report Share Posted March 13, 2019 DC Audio makes some nice subs. Been wanting to try their 18's. Level 3 12's would work on your power pretty well. Sundown for the win tho lol. I'm sorry but I love Sundown. Haha Link to comment Share on other sites More sharing options...
Joshdashef Posted March 13, 2019 Author Report Share Posted March 13, 2019 Just now, ToNasty said: Sundown sa12s should do great in that size enclosure I know sundowns a little underrated sometimes how much power can those really take? SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
DiBo Posted March 13, 2019 Report Share Posted March 13, 2019 Just now, Joshdashef said: I know sundowns a little underrated sometimes how much power can those really take? I had 2k RMS going to mine. They handled every bit of it well. Sounded great too. Link to comment Share on other sites More sharing options...
Joshdashef Posted March 13, 2019 Author Report Share Posted March 13, 2019 3 minutes ago, DiBo said: I had 2k RMS going to mine. They handled every bit of it well. Sounded great too. 2k rms each? or for the pair? SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
Joshdashef Posted March 13, 2019 Author Report Share Posted March 13, 2019 I looked at both the SA12s and Level 3 12s. I think its between 6 eggs and a half dozen, so close either would fit my setup. In saying that, the SA12s are 194 each and the Level 3s are 296 (base model). Since I will eventually be upgrading later I'd rather save the extra 100$ per sub for other upgrades. Going with the SA12s Thanks for yalls comments SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
ToNasty Posted March 13, 2019 Report Share Posted March 13, 2019 1 hour ago, Joshdashef said: I know sundowns a little underrated sometimes how much power can those really take? Clean power and youre fine ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
DiBo Posted March 13, 2019 Report Share Posted March 13, 2019 7 hours ago, Joshdashef said: I looked at both the SA12s and Level 3 12s. I think its between 6 eggs and a half dozen, so close either would fit my setup. In saying that, the SA12s are 194 each and the Level 3s are 296 (base model). Since I will eventually be upgrading later I'd rather save the extra 100$ per sub for other upgrades. Going with the SA12s Thanks for yalls comments The sa12's actually outperformed the level 4's I had. I can't explain it but they did. Sounded better without question too Link to comment Share on other sites More sharing options...
