Audio877 Posted March 14, 2019 Report Share Posted March 14, 2019 I am planning on installing two soudqubed hds3 15 inch subwoofers in my car. They are 1200 watt rms each and I will probably put them on a 2250 watt rms amp in a ported box. In the future I will also add a 4 channel amp with 100 rms per channel for the mids and highs, so I will want to consider that when figuring out my electrical system. And I have all stock electrical at the moment so what would you recommend I do for my electrical system? HO Alternator? Big 3? Both? Battery? I am new to car audio so any help would be great. I have a Land Rover Lr3 2006 Link to comment Share on other sites More sharing options...
Wishuponasub Posted March 14, 2019 Report Share Posted March 14, 2019 I recommend Jonathan Patrick on Facebook. He builds alts for Custom Electric Services. If he can't build it then he will send you to Mike Singer who I also recommend. A 270 amp with the biggest XS Power agm you can fit under the hood will do just fine for you buddy. Yes you need to do the big 3. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4 Link to comment Share on other sites More sharing options...
Dragonsyph Posted March 15, 2019 Report Share Posted March 15, 2019 For 2k rms you could probly get away with stock alt and some beefy ah agm bats. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA Link to comment Share on other sites More sharing options...
BassMunky Posted March 15, 2019 Report Share Posted March 15, 2019 What the stock alt? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Audio877 Posted March 18, 2019 Author Report Share Posted March 18, 2019 Thanks, pretty sure the stock alt is like 90 amps and i never plan on running it with the car off. eBay alts are very cheap but are they bad? There is a 250 amp one for my car model Link to comment Share on other sites More sharing options...
BassMunky Posted April 4, 2019 Report Share Posted April 4, 2019 90x 14.3 =1287 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Dragonsyph Posted April 4, 2019 Report Share Posted April 4, 2019 On 3/18/2019 at 12:18 PM, Audio877 said: Thanks, pretty sure the stock alt is like 90 amps and i never plan on running it with the car off. eBay alts are very cheap but are they bad? There is a 250 amp one for my car model Every thread I have read about "ebay alts" they almost always end up not doing even close to rated amps at idle or cruise. They also tend to break down pretty fast. Just think of them like the amps on there that say 10,000 watts then dyno for 1500 and blow up. If its a resell of a name brand alt then maybe, depending on how worn the internals are. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA Link to comment Share on other sites More sharing options...
BassMunky Posted April 5, 2019 Report Share Posted April 5, 2019 200 amp alternator Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
