necromonster Posted March 15, 2019 Report Share Posted March 15, 2019 So I bought the Taramps md8000.1 and the non premier version doesn't come with the m1 LED monitor. It's basically a remote LED indicator for the power, clip, and protect LED's on the amplifier. The jack for the monitor looks like it's a standard 4 pin phone jack (rj11) Does anyone know the pinout of the jack? I'm thinking about building a separate box with my own LED's instead of forking out the $50 for one from taramps. I'll probably just take a phone cord, cut it and strip a few inches off of each individual wire inside the cable. That way I can test the voltages with a multimeter as the LED's light up on the amp to map out the pins if anyone else on here hasn't done so already. Link to comment Share on other sites More sharing options...
necromonster Posted March 16, 2019 Author Report Share Posted March 16, 2019 so after some testing the pin out is as follows. on the plug side there are 4 wires with different colors. (black, red, green, yellow) the green wire is the "CLIP" indicator signal the red wire is the "ON" signal the black wire is the "PROTECT" indicator signal the yellow wire is the "GROUND" signal Link to comment Share on other sites More sharing options...
