lovetoslam69 Posted March 16, 2019 Report Share Posted March 16, 2019 Hi, I'm installing 1 Rockford Fosgate p2 12 which I'm running with a Rockford Fosgate 500x1d wired to 2 ohms. When my bass hits my amp goes into protection mode. I rewired the sub to the box, made sure the ground was good. I'm totally lost on what to check next, any help would be appreciated. Thank you Link to comment Share on other sites More sharing options...
Joshdashef Posted March 16, 2019 Report Share Posted March 16, 2019 Do you have a multimeter? check the resistance of the pos/neg speaker wires with them disconnected from the amplifier and verify they are indeed 2 ohms if you are lower than that the amp will go into protect, as it is only 2 ohm stable. I have used the prime 500 amp and have never had problems, even bought another for my dads bronco. Any pics of the install would help also SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
Infektid Posted March 18, 2019 Report Share Posted March 18, 2019 check the voltage when the bass hits . low voltage can also trigger that . and then make sure the grounds and positives are good Link to comment Share on other sites More sharing options...
ckeeler11 Posted March 21, 2019 Report Share Posted March 21, 2019 How did you set the gain? Link to comment Share on other sites More sharing options...
BassMunky Posted March 21, 2019 Report Share Posted March 21, 2019 How you check the ohm mine was fluctuating when disconnected. 2 12 dual 1 ohm wired to 1 ohm if I remember or 2 ohm was reading last check like 1.35 ohms Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
