bigtinybob Posted March 18, 2019 Report Share Posted March 18, 2019 are the amps clip light accurate or close to it ..im usung the skar lp.750.1 dv2 on 2 crossfire c3s at 1 ohm.the light never comes on unless its a really heavy bass song.so i cut the gain back alittle and then if i turn up the music alittle more it comes back on. Link to comment Share on other sites More sharing options...
realflow100 Posted March 18, 2019 Report Share Posted March 18, 2019 the music itself can have clipping regardless of your amp gain. so there could be clipping at 1/10th volume just because the song has clipping in it. I'd re-set the amp gain with pure sinewave test tones. and check for clipping with sine waves and by ear to make sure theres no clipping at any frequency. so check the frequencies that give the most power to your subwoofers as well. you dont want any clipping at any frequency with a sinewave. make sure your volume on your head unit and stuff is set to the highest. before setting your gain on the amp. start out with the gain on the lowest and slow turn it up until you hear distortion. or the clipping light comes on. and back it down a little. you can also use a clamp AC meter with a multimeter to measure the RMS AC voltage to calculate the watts going to your subwoofers to make sure you arent overpowering your subwoofers past their RMS wattage rating once the gain has been set. its ok if the clipping light comes on occasionally (peaks of songs) but shouldn't be continously lighting up. play songs that dont have a whole lot of clipping in them. listen to them at low volume just to make sure they sound clean and dont sound distorted. if they sound clean at low volume. dont worry about it some songs can trigger the clipping indicator from hard hitting bass peaks. Link to comment Share on other sites More sharing options...
bigtinybob Posted March 18, 2019 Author Report Share Posted March 18, 2019 alright mostly the music i played that the light came on was only rap with heavy bass but i did turn the gain back down maybe a 1/8 of turn and its sounds much better but the light just came on and back off with a heavy bass drop.but as you said clipping occurs even at the low settings. Link to comment Share on other sites More sharing options...
realflow100 Posted March 18, 2019 Report Share Posted March 18, 2019 if you turn your volume down to like half. do some songs still make the clipping light activate when the bass would "hit"? or what certain points your talking about with heavy bass drop? that shouldn't neccessarily be an issue as long as the gain is set right with sinewave tones of -0dB Link to comment Share on other sites More sharing options...
bigtinybob Posted March 20, 2019 Author Report Share Posted March 20, 2019 for instance mercy by pollie pop .the bass notes is usually when it comes on.unless i turn the bass knob back alittle then it goes off.so im assuming it just normal under certain notes Link to comment Share on other sites More sharing options...
AaronT Posted July 3, 2019 Report Share Posted July 3, 2019 A soft clip is perfectly acceptable Link to comment Share on other sites More sharing options...
SPL DB Posted July 3, 2019 Report Share Posted July 3, 2019 Usually when a soft clip happens some times the gain needs to be just slightly turned down a small amount, I had it happen and adjusted the gain a lil and the amp never went into protect again. Link to comment Share on other sites More sharing options...
the_garynator Posted July 3, 2019 Report Share Posted July 3, 2019 A friend of mine tested his clip light vs a dd-1 and it was dead on with the dd-1. I don't remember what brand amp it was off the top of my head, but I'd say they're reasonably accurate. Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx Link to comment Share on other sites More sharing options...
AaronT Posted July 3, 2019 Report Share Posted July 3, 2019 I seen Rockford new C.L.E.A.N. punch amps tested against dd1also spot on Link to comment Share on other sites More sharing options...
