Using DD-1 on a 2-Channel
Hello, I just bought a 2-Channel amplifier to power my new SPL tweeters. I'm a bit confused on how I should use my DD-1 to set the gain properly though.
From the manual:
5. Using included harness, connect DD-1 to output of amplifier. Connect the red harness lead to the Left Speaker (+) terminal, connect the black to Amplifier Ground. (Note: Most multi-channel amplifiers have the signal on Left (+) and Right (-).
So I put the positive lead from the DD-1 to the Left Speaker positive, and the negative probe into the negative power connection on the amplifier? Can I just stick it in the 0 gauge negative, like if I were testing voltage with a multimeter?
I just had to ask here to be 100% sure, don't wanna blow anything up. 😝
Uhh my manual says this "5. Using included harness, connect DD-1 to output of amplifier. Connect the red harness lead to the Left Speaker (+) terminal, connect the  black to Left Speaker (-). "
Not amplifier ground, I have no clue where you got that from
Different revisions showed better results using different points.
From the manual:
I just had to ask here to be 100% sure, don't wanna blow anything up. " src="https://twemoji.maxcdn.com/2/72x72/1f61d.png">
Yes, that's how you do it.
  • Thanks (+1 Rep) 1
  • Who's Online   1 Member, 0 Anonymous, 1659 Guests (See full list)
