Mike12086 Posted March 19, 2019 Report Share Posted March 19, 2019 Just got a new Jeep Cherokee and want to keep the factory HU. From what I understand they are now programmed where if they don't sense the ohm load of the speaker it shuts down that channel. What would be the proper way to test output? Could I keep the speaker connected or would it be better to use a fixed value resistor? Thanks Mike 1 Quote Link to comment Share on other sites More sharing options...
reedal Posted March 22, 2019 Report Share Posted March 22, 2019 If the DD-1 is connected to both the positive and negative, it may work as the DD-1 should provide some load on the HU. I am not sure though. Try it and let us know, that way no matter the outcome, someone who may come into the same situation as you might be able to search and find the answer Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
