Skar audio Zvx 12 dual enclosure
So what improvements do you think your going make deviating from factory recommendations ???
I'm not sure exactly, but going with factory recommendations didn't exactly work out for a single enclosure. Everything was tuned right and the sub was bottoming out (running rms power) at a volume well below clipping on my head unit. So far both shops and friends that I've had look at it have all said that the problem is the box is too big. The volume was 3.8 cubic feet taking into account the .65 cubic foot port displacement and the .15 woofer displacement and tuned to 34hz like their website recommended.
Edited by Justtrillin77
Not just the enclosure, but most likely amplifier power. Running recommend ???
@mfdoom7 It was tuned with a dd1 so I'd assume it's not clipping. But I was running a skar rp2000 at 1 ohm and I had the gains set damn near all the way down. And now I'm running it at 4 so I'm Pushing around 800 watts out of it. I hooked up my friends skar rp1500 at 1 ohm, tuned it with the dd1 and ran into the same bottoming out issue even at rms.
It’s a box issue can we see pics of the box.
