Joshdashef Posted April 3, 2019 Report Share Posted April 3, 2019 Going to be moving my mids and high amp eventually but I may need to extend my speaker wire or re-run four pairs of wire. That is why I was wondering if I could just extend each run another 2-3 feet at most with solder connections at the end of where they reach now? Instead of re-run all four pairs.... Does this hurt the quality of sound output? anything I should worry about doing this? Wires 14 gauge if that matters powered off a P600x4 mids on two channels tweeters on two channels. Will be using the same wire to solder and extend if I go this route. SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
mothra Posted April 3, 2019 Report Share Posted April 3, 2019 no real issue, may melt some of the jacket near the solder joint b/c the gauge of the wire. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Dragonsyph Posted April 6, 2019 Report Share Posted April 6, 2019 Cca or ofc wire? ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA Link to comment Share on other sites More sharing options...
AaronT Posted June 28, 2019 Report Share Posted June 28, 2019 Solder is the best electrical connection next to a solid straight run of uninterrupted wire. As long as you don't get cold joints and that solder flows well, you will never know the difference Link to comment Share on other sites More sharing options...
SnowDrifter Posted June 28, 2019 Report Share Posted June 28, 2019 On 4/6/2019 at 8:15 AM, Dragonsyph said: Cca or ofc wire? Good question. Can't solder CCA! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Guest Posted June 28, 2019 Report Share Posted June 28, 2019 rerun, dont fuck around with wires its very easy 2 get whine or some other problem from shitty wiring. Link to comment Share on other sites More sharing options...
Ron36 Posted June 28, 2019 Report Share Posted June 28, 2019 I would just braid the wire together very strong and heat shrink it , I stopped soldering wire years ago unless it’s on a circuit board . Had a class on this awhile back and braided and crimp joints hold better then solder. Solder isn’t flexible and can crack from vibration. Not to mention only about half the people that solder really know how to do it right , U don’t just put a drop of solder on a wire and call it soldered I’ve seen this a ton in car audio. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
Ron36 Posted June 28, 2019 Report Share Posted June 28, 2019 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
