Dannymen00 Posted April 30, 2019 Report Share Posted April 30, 2019 Am i running out of power ? Its feels like i miss allot of power If i put te amp up to 75% it sometimes gives a pop like is running out of power. Got a little bit of lamp dimming to. te current ampere it is pulling i dont know ( battery is full ) .will swapping to a optima yellow 80ah( 945 cold cranking ) solve mij problems ? Currently running: Dd815 dual 1 ohm on 2 on Excursion hxa3k ( 20mm2 50mm3 is on its way) 60 ah bassic battery ( 515amp cold crank) 70 amp dynamo Link to comment Share on other sites More sharing options...
paidnfull Posted April 30, 2019 Report Share Posted April 30, 2019 Explain, "put the amp up to 75%". If you're talking about the gain/level, that isn't how it works. Link to comment Share on other sites More sharing options...
Bj3ll0 Posted April 30, 2019 Report Share Posted April 30, 2019 Looks like your taxing the alt and draining batt, with that power you should be fine with about 75ah of agm and a big 3 but that agm should be dedicated. Or go bigger alt and big 3, and should be good if it’s only doing >1500 if you invest in the alt now you will have the foundation for a better system later when you decide it’s not enough and can just add batteries 2012 Kia Soul Infinity reference 6.5's Coaxials 2x Soundqubed HDS312 @ 32hz (hdx312 waiting on alt) 1x Skar Audio RP-2000 (deaf bonce 4k on floor waiting on alt) 1 x Northstar group 35 front 1x Nortstar SMSAGM220 rear (have a second one waiting on alt) 0 gauge Sky High OFC BIG 4 Link to comment Share on other sites More sharing options...
Dannymen00 Posted April 30, 2019 Author Report Share Posted April 30, 2019 Yeah paidnfull, The gain but it got no distortion a friend of me checked distortion at 88% Bj3llo Did the big 3 whit 20mm2 cables Altanator i was thinking about as 80 ah alternator is the biggest for mij car stock ( maybe make a peugeot gti one fit 120 ah ) But that power i got now maybe causes some heavy dips that make a small pop ? As voltage drop and not a great backup Link to comment Share on other sites More sharing options...
