jnasty Posted May 10, 2019 Report Share Posted May 10, 2019 Hey guys I've got my amp running @ 1 ohm powering a nsv4 18. As of now I've got it set with a -10db tone with the dd1, but I'll smell coil 1/2 way through the song. Yes, it's a 4000+ watt amp.. but I highly doubt the sub is actually seeing anything over 3k & from what I've heard, the nsv4 can take that all day. Which leads me to the logical conclusion... I'm clipping still. The amp is equipped with a clipping LED on the side.. has anyone ever soldered on another LED and ran the wire to the dash.. as a real time clipping indicator? Thoughts if this would work??! Definitely don't want to smoke another expensive woofer (rip tc sounds lms ultra) Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
Guest Posted May 10, 2019 Report Share Posted May 10, 2019 sounds like your song is full of distortion Link to comment Share on other sites More sharing options...
Mike4068 Posted May 10, 2019 Report Share Posted May 10, 2019 Try a - 7.5 dB track. If the songs you are listening to are recorded at a higher level then you will still be clipping with your gains set properly. I had the same problem and this helped a lot. I still have some songs that I can't turn up as much before the stinky genie comes out. As I understand it those leds on the amp are measuring rail voltage and not distortion and aren't really accurate. My amp was in the red before the dd-1 registered distortion. Link to comment Share on other sites More sharing options...
jnasty Posted May 10, 2019 Author Report Share Posted May 10, 2019 Thanks guys, after reading up a whole lot, I think its a combo of things.. I've got no name batteries, they die within 2min. Going to the store today to grab some bunny's or Duracell. Maybe I'm getting false readings. Gonna try -7.5 and hopefully that'll fix my issues Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
