Robin Dobbie Posted May 26, 2019 Report Share Posted May 26, 2019 I think one time I got it to show 2 watts, but mostly it says 0 watts. One speaker lead is running through the hole in the meter, and the leads are connected(actually screwed into) to the speaker terminals. https://www.mediafire.com/file/g5le0ybki1lohnb/out.mp4/file Quote Link to comment Share on other sites More sharing options...
mothra Posted May 26, 2019 Report Share Posted May 26, 2019 better off contacting them directly Quote if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 26, 2019 Report Share Posted May 26, 2019 The user manual seems to indicate using a sine wave rather than music. Have you tried that? Admittedly I don't own one so I'm not familiar with typical behavior for these units Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Robin Dobbie Posted May 26, 2019 Author Report Share Posted May 26, 2019 Tried both. I did music also so that I would at least have transients powerful enough so that I could achieve peaks that I knew for a fact, beyond any stretch of the imagination were more than an order of magnitude greater than .9 to 2 watts. Quote Link to comment Share on other sites More sharing options...
Gerardo Vasquez Posted November 17, 2020 Report Share Posted November 17, 2020 On 5/26/2019 at 9:37 AM, Robin Dobbie said: Tried both. I did music also so that I would at least have transients powerful enough so that I could achieve peaks that I knew for a fact, beyond any stretch of the imagination were more than an order of magnitude greater than .9 to 2 watts. Hey Robin were you able to figure out this issue I'm having the same problem Quote Link to comment Share on other sites More sharing options...
East Coast Tim Posted July 25, 2021 Report Share Posted July 25, 2021 I am having a similar problem where I am only seeing maybe 1-5 watts max when I know it should be more like 2000-2500 in any respective mode. And my other problem is that the meter always shows either 200.0 ohm or sometimes >200ohm when I have a 2ohm setup... Also the button response is sometimes non existent but this is the least of the issues. I have tried test tones and music, three different new batteries and two systems, all to no avail Unfortunately I see VERY few answers or solutions to AMM-1 issues on this forum. This was the first use ever on this unit and I am extremely disappointed as I was over the moon when it arrived last week from Sky High and overall just stoked to own a tool like this. I am really hoping it is something I am doing wrong even though I have done it all exactly by the manual with many attempts. Quote Link to comment Share on other sites More sharing options...
Arthur79 Posted July 25, 2021 Report Share Posted July 25, 2021 2 hours ago, East Coast Tim said: I am having a similar problem where I am only seeing maybe 1-5 watts max when I know it should be more like 2000-2500 in any respective mode. And my other problem is that the meter always shows either 200.0 ohm or sometimes >200ohm when I have a 2ohm setup... Also the button response is sometimes non existent but this is the least of the issues. I have tried test tones and music, three different new batteries and two systems, all to no avail Unfortunately I see VERY few answers or solutions to AMM-1 issues on this forum. This was the first use ever on this unit and I am extremely disappointed as I was over the moon when it arrived last week from Sky High and overall just stoked to own a tool like this. I am really hoping it is something I am doing wrong even though I have done it all exactly by the manual with many attempts. I haven't seen that behavior out of my AMM-1 and I use it to measure both music and sign waves for real-time power and peak. Maybe reach out to D'Amore Engineering for support: [email protected] I know Steve Mead is pretty customer obsessed and I expect Tony and Juan are just as customer obsessed as Steve. Hopefully they can get you sorted out. Quote Link to comment Share on other sites More sharing options...
East Coast Tim Posted July 25, 2021 Report Share Posted July 25, 2021 Both are wayyy off of the realm of expectation (It must be a defect) I do plan on calling tomorrow (Monday) morning... Quote Link to comment Share on other sites More sharing options...
