Maximum Car Voltage
I wouldn’t go over 15v , my truck hits 15.2v at times but U go to high and PCM’s fry . Also every manufacturer is different some PCM’s might turn off before damage . It’s a hard thing to follow but safe is always 14.7v.
It varies from vehicle to vehicle tbh.
I think 14.7 is a bit conservative given that  PCM controlled smart charging systems go into the 15+ range. My tahoe charges at 15.2 before dropping down to 13.1.
My old subaru would tolerate 16.4 before the ABS went into safe mode and shut down. It burned through halogen bulbs like potato chips though. I eventually got most everything swapped to LED
FWIW: Consider an alternator failure that might push a stock charging system to the 16-17v range. The systems have a pretty wide range of both voltage and temperature conditions they're intended to run at. This is by no means a guarantee of safety. More of a contextual piece of info. If you're not willing to test limits yourself, see if you can contact either the manufacturer or a local shop to see if they have access to documentation on voltage ranges of various modules.
If you could provide more info on the project you're working on, perhaps we might be able to suggest a better solution
I have fiat punto mk1 and I was thinking to get Yinlong LTO batteries.. I heard that I need a little higher voltage to get all of them.. Thats why I'm asking.
5s pack and charge at 13.8? :unknw:
21 hours ago, Antoni Čović said:
What is maximum charge voltage that average car can safely endure? Thanks
Average vehicles run a 12 volt system for a reason ... Just Saying
1 hour ago, Antoni Čović said:
5x2.3v is 11.5v.. I just heard that to get all of them you need over 14.4v and that 14.4v is minimum to charge them.
I wouldn't touch lithium if I were you
  • Who's Online   1 Member, 0 Anonymous, 1248 Guests (See full list)
