17 minutes ago, Audiohz said:
I'm at 5.34 cube total net for two subs 2.5 each
do a fiq 18 on that 2000 watts sealed just seal the holes and make a new top if you have enough area to have an 18 lol   it can be a 2.5 to a 4 cubed box   hell it can be 5 cubed ported if you could make an external port lol
Sealed boxes are very Punchy but never had an issue with lows , I would just try sealed and if you don’t like it build a new box but I’m pretty sure if you have sealed now you’ll be fine with these subs sealed. I went with 3 10’s sealed to compensate for 2 ported 10’s. I also built a ported box for 2 10’s and it was very close to the same sound as the sealed but not as punchy though. I really liked the sealed sound. If U have room for ported I would go that route.
Edited by Ron36
Pics of my sealed and ported boxes.
With your 10's where they at spec to sundown sealed spec ? Did you use poly fil or anything in the box?
 I did use polyfill, I called Sundown and each sub had its own chamber so like 3 separate boxes  , that’s what they recommended. Built to Sundown spec. I’ve heard the V3 SA’s don’t like sealed but I could be wrong.
Edited by Ron36
Good to know ... thanks for the help man. I'm going to get some in the am . As far as I know rule on poly fil is about a pound per cube so I'll try that.
Sundown also said if running sealed run more power to subs so 1k each would be perfect butt make sure your electrical is good.
  • Thanks (+1 Rep) 1
  • Who's Online   0 Members, 0 Anonymous, 233 Guests (See full list)
