Need help ported box for 4 skar vvx8v3
jayierra
I have 4 Skar VVX8-V3 and i need help with a box design at the moment i need trunk space in my car so the most i can do is a 2.5 to 2.6 cubic ft box after displacement dimensions is 40 inches long 12 inches high and 14.5 inches deep. would the subs work okay with the amount of cubic ft i have a port tube which is a flared 4 inch port 10.5 inches long i am unsure what the tune hz would the box be tune to. so my questions are
would the subs be okay in this enclosure?
would i need a double baffle for these subs?
what hz tune would a 4 inch port 10.5 inches long be for the enclosure?
all answers will be appreciated i am kind of new to this as this is my first attempt to build a box for my scion FR-S please help.
You should have enough space for those subs based on the dimensions you gave.
How much power are you going to be running?
A single 4" port is unlikely to be enough port area.
Builds:
I’m was gonna run it on 1500 all together so 375 per sub I could go 2000 watts but all I have for power upgrades are the big 3 still waiting on my 450 amp alternator to come in
Do you think 2 4 inch ports would be enough port area ?
No, that's still not enough.  You need three 4" ports, or a slot port of about 40 sq in of port area.
You are basically in the same spot as ehall8702 was a few days ago.  1500 watts doesn't sound like a ton of power, but into a box for four 8"s it is and it takes a fair amount of port area to let that sound energy out.
Here is his thread for more info:
FYI, if you think you are going to run more power later, you should plan for that now with your port area.  With that being said, you will NEVER hear the difference between 1500 and 2000 watts.
Builds:
I tell ya if triticum gives ya advice , definantly take it. Dude knows his shit! My 4 8s are so violent it's almost unbelievable. I think I actually broke part of my cab on my truck and they aren't even broken in yet.
Thank you both so much for the help I actually took his advice and ran 3 4 inch ports and I even made a second panel to try and hear the difference with the single and he was right my whole car is flexing hard even with second skin sound deadening full coverage in my FR-S
  • Who's Online   2 Members, 0 Anonymous, 1454 Guests (See full list)
