98 SNAKE EATER Posted June 14, 2019 Report Share Posted June 14, 2019 Looking to add a basic sub amp to my existing factory system (10 Speaker JBL/Entune in my Toyota Van) Since I'll be adding an NVX mini amp, I felt it was just fitting to use an NVX line converter, so I looked up the XPLOC2 which seems to fit my needs and budget https://www.nvx.com/xploc2-300-watt-2-channel-line-output-converter/ Things is, I've had several people tell me that I should splurge on the LOC and go with an LC2i from AudioControl due to the AccuBass feature. https://www.audiocontrol.com/car-audio/factory-system-upgrade/lc2i/ Is this really worth the added price over the NVX unit? Link to comment Share on other sites More sharing options...
slowfkncar Posted June 14, 2019 Report Share Posted June 14, 2019 Can't speak for the nvx loc, but I personally prefer the way lc2i's sound when using the active subwoofer outputs from factory amps. Those outputs are usually pre-equalised, accubass can help flatten that. Link to comment Share on other sites More sharing options...
SnowDrifter Posted June 14, 2019 Report Share Posted June 14, 2019 No comparison threads thanks! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
