Finally time to build my box, any help welcome. (Cut sheet) (design)
Orderd my NSV4 18” dvc 2ohm,  final load will be 1ohm,  ssf will be at 25hz so a box tunes to 28 would be nice.
Ill be using an Orion hcca 5k v2,  dyno sheet shows 5500 @ 12.6v.
Any other info needed let me know.
SUB DEPTH 15 1/4"
SUB MOTOR WIDTH 6 1/2"
Sub displacement about .27
Room i have is 48" wide and about 30" deep.
Sub up port back.
Do you have a specific question?  What kind of help are you looking for?
Builds:
A cut sheet with sizes etc, assuming 1” mdf will be used.
Need port back sub up.  Will be going in back of an 05 Tahoe.
Unless you already have a pile of 1" MDF you want to use up, there is no good reason to use 1" MDF.  Zero. None.
What are the max dimensions of your space?
Builds:
Once i get off work I’ll measure to see.  Tons of room since I took out 3ird row seats.
No mdf?  So we talking like 7 or 11 ply birch?
Havent built a box since high school some odd 15 years ago lol.
You can use MDF if you want, though I would argue that a quality plywood has its benefits.  What I was mainly referring to is that you wanted to use 1" thick material.  A sheet of 1" MDF weighs about 120 lbs.  It absolutely sucks to work with.  All the extra weight isn't gaining you much either.  You would be much better off with 3/4" MDF and using the weight you saved vs 1" material to add bracing and doubling up on certain panels that would actually benefit from being two layers thick.
Builds:
That makes a lot of sense, and thank you for all the information, I’m lacking in this department.  and 3/4 is a lot cheaper here.
Sorry
for the delay works been Killing me.
About 30” deep and 48” wide is what I have to play with.
Wheres all the box guys at?  I was talking to someone like 4 months ago about a design but i totally forgot what his name was.  Sheder or shretter or something.
Side note, the d3100 DID not fit in the front like i thought it would, so i just orderd a D3400 lol.
  • Who's Online   1 Member, 0 Anonymous, 815 Guests (See full list)
