CstrokerV Posted June 30, 2019 Report Share Posted June 30, 2019 Uhhh I guess the guys in the lanes with limited fuse ratings need to talk to gunnel don’t want to under power those amps lol my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
will77530 Posted June 30, 2019 Report Share Posted June 30, 2019 11 minutes ago, CstrokerV said: Uhhh I guess the guys in the lanes with limited fuse ratings need to talk to gunnel don’t want to under power those amps lol You mean to tell me a fuse won’t act like a resistor it’ll just pop when it gets too much current almost like it was designed to work as a safety mechanism???? no fucking way that can’t be true Link to comment Share on other sites More sharing options...
Jeremy009 Posted June 30, 2019 Author Report Share Posted June 30, 2019 4 hours ago, Mike4068 said: You should be concerned with keeping your voltage up not your amps. The 120amp fuse is not poping....my voltage stays on 13.7 - 13.9 at close to max volume while driving and 13.1 parked at 800rpm,i tuned using a dd1 meter. Could that mean when i had it direct that i was not seeing nowhere close to 200amps or 2000rms? Because am metering the same numbers direct and with the 120amp fuse.... it also sounds exactly the same to my ear Link to comment Share on other sites More sharing options...
will77530 Posted June 30, 2019 Report Share Posted June 30, 2019 It means you are pulling less than 120a most likely due to box rise which is something you really shouldn’t worry about on a daily system Link to comment Share on other sites More sharing options...
Mike4068 Posted June 30, 2019 Report Share Posted June 30, 2019 ^^what he said. I think your system is fine but I'd still put the proper fuse in. Link to comment Share on other sites More sharing options...
Jeremy009 Posted June 30, 2019 Author Report Share Posted June 30, 2019 Ok thanks guys. So this means if i want more output i need a bigger amp and not like any electrical upgrades to get more out of the deaf bounce amp i currently have?? Right? Link to comment Share on other sites More sharing options...
SkarredSierra Posted June 30, 2019 Report Share Posted June 30, 2019 You can always upgrade electrical. Imo your electrical can never b too strong. If it was me id do 2 runs of positive 0 front to bak then upgrade that alt but honestly that voltage sounds ok for a daily driver. Just put in a nice alt wen the stock one shits the bed. If you havent done it upgrading your alt wires and main battery ground will help alot. Link to comment Share on other sites More sharing options...
will77530 Posted June 30, 2019 Report Share Posted June 30, 2019 16 minutes ago, Jeremy009 said: Ok thanks guys. So this means if i want more output i need a bigger amp and not like any electrical upgrades to get more out of the deaf bounce amp i currently have?? Right? No but I am far too sober to learn ya Link to comment Share on other sites More sharing options...
White Lightning Posted June 30, 2019 Report Share Posted June 30, 2019 12 hours ago, Jeremy009 said: I got a deafbounce aak 2000.1d...manual recommends a 200amp external fuse. All i got is a 120amp. What would happen if i use the 120amp vs running it direct in from the battery? That is a max fuse rating. Just for daily jamming, That 120 amp fuse should be fine. If you plan to compete, I'd suggest upgrading Electrical before going up in fuse size. Please, do not run your system without fusing. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
