Ripkon Posted July 7, 2019 Report Share Posted July 7, 2019 I recently installed a set of Morel Maximo 6 and a 4 channel amp. Also running 2 Sundown LCS in ported box tuned to 32hz on a Soundqubed 1250. Im running active from my HU. I have used the Tape Measure to put in the distance of my speakers, but the center stage isnt right. I have read several Forums and tut's about it, but still struggling. Here is my Problem. The center isn't very defined. I'm running 100hz-31.5khz on Mids and 31.5 on tweets on 24db slope because i dont know alot of phase and being able to hear the phase difference. Another quest do i need to adjust the speaker level/db on either side? any input would be great. Link to comment Share on other sites More sharing options...
ToNasty Posted July 7, 2019 Report Share Posted July 7, 2019 You may have the mids crossed to high. Also how are your speakers staged? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
Ripkon Posted July 7, 2019 Author Report Share Posted July 7, 2019 You think I should leave a gap? Edit that wire isnt hanging there. That was just placement check Link to comment Share on other sites More sharing options...
Ripkon Posted July 7, 2019 Author Report Share Posted July 7, 2019 Link to comment Share on other sites More sharing options...
ToNasty Posted July 7, 2019 Report Share Posted July 7, 2019 Try placing the tweeters in the bottom corner of the each side of the windshield. Lower the hp on the tweeter for about 2600 and. Same with the mid. I'm still having trouble seeing where the misld is at ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
Ripkon Posted July 7, 2019 Author Report Share Posted July 7, 2019 3 minutes ago, ToNasty said: Try placing the tweeters in the bottom corner of the each side of the windshield. Lower the hp on the tweeter for about 2600 and. Same with the mid. I'm still having trouble seeing where the misld is at I just uploaded a picture pointing the to mid. Its behind the door panel Link to comment Share on other sites More sharing options...
ToNasty Posted July 7, 2019 Report Share Posted July 7, 2019 I'm thinking you'd have better results placing the mids in the kick panel. But adjust how I said first and see if that helps ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
mothra Posted July 7, 2019 Report Share Posted July 7, 2019 the passive crossovers are crossed at 3.5kHz. I'd start by crossing there or higher. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Ripkon Posted July 7, 2019 Author Report Share Posted July 7, 2019 3 minutes ago, mothra said: the passive crossovers are crossed at 3.5kHz. I'd start by crossing there or higher. yea the crossover is crossed at 3.5hz. I was doing some reading and ive read 31k is a really good cross-point for them. Really just trying to get my sound stage correct and centered. Link to comment Share on other sites More sharing options...
