Ripkon Posted July 30, 2019 Report Share Posted July 30, 2019 I'm about to gain match my amps and I cant use the oem with 2 amps. Was told to get a pac lc1 but didn't want another small knob. Used a Hammond 1590a (wanted darker purple, but will order another and paint). I also Knuconeptz Y rca so the RCA's look better. Figured I would share if anyone else wanted to make one Link to comment Share on other sites More sharing options...
Jessica Posted July 30, 2019 Report Share Posted July 30, 2019 looks great! Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
BassMunky Posted July 30, 2019 Report Share Posted July 30, 2019 Look like vape Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Ripkon Posted July 30, 2019 Author Report Share Posted July 30, 2019 12 minutes ago, strangeduck said: looks great! Thanks. I'll show pics once I get the Knuconeptz RCA'S soldered in Link to comment Share on other sites More sharing options...
Ripkon Posted July 30, 2019 Author Report Share Posted July 30, 2019 Just now, BassMunky said: Look like vape Lol yea. I used to build box mods Link to comment Share on other sites More sharing options...
Derp Posted May 22, 2020 Report Share Posted May 22, 2020 Looks good. I may try this with an old RX 200 I have LOL. For me with the soldering, because the pac 1 rcas dont look cool, would be a turn off. I can do it but parts plus time seems I'd end up spending 30-35 bucks when I can get a low tier custom for 45 ish. Edit: On second thought I may try this LOL many things you can put it in LOL What size grommets did you use? Link to comment Share on other sites More sharing options...
Joshdashef Posted May 22, 2020 Report Share Posted May 22, 2020 1 hour ago, Derp said: Looks good. I may try this with an old RX 200 I have LOL. For me with the soldering, because the pac 1 rcas dont look cool, would be a turn off. I can do it but parts plus time seems I'd end up spending 30-35 bucks when I can get a low tier custom for 45 ish. Edit: On second thought I may try this LOL many things you can put it in LOL What size grommets did you use? You can get those grommets off amazon, whole multi pack of different sizes for real cheap I use them whenever running wire if I come across some sheet metal I want to prevent chaffing on even if you have to drill it. https://www.amazon.com/dp/B01NAN025Y/ref=cm_sw_r_cp_api_i_Jk.XEb6C5P6AW SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
never knows best Posted May 22, 2020 Report Share Posted May 22, 2020 very nice, thanks for post the info and pics Link to comment Share on other sites More sharing options...
Derp Posted May 24, 2020 Report Share Posted May 24, 2020 On 5/22/2020 at 11:42 AM, Joshdashef said: You can get those grommets off amazon, whole multi pack of different sizes for real cheap I use them whenever running wire if I come across some sheet metal I want to prevent chaffing on even if you have to drill it. https://www.amazon.com/dp/B01NAN025Y/ref=cm_sw_r_cp_api_i_Jk.XEb6C5P6AW Thanks, Just bought the grommets from your link. I bought all the things to do this when I posted my last comment LOL. Thanks for the info/pics. Link to comment Share on other sites More sharing options...
Joshdashef Posted May 24, 2020 Report Share Posted May 24, 2020 1 hour ago, Derp said: Thanks, Just bought the grommets from your link. I bought all the things to do this when I posted my last comment LOL. Thanks for the info/pics. Awesome! SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
