twotoneelcamino Posted August 20, 2019 Report Share Posted August 20, 2019 it’s a 9 foot run to my crescendo s4. i see i only need 4 awg but can i use 1? Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 20, 2019 Report Share Posted August 20, 2019 Sure, should be fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
BassMunky Posted August 21, 2019 Report Share Posted August 21, 2019 Ok Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
k58.cross Posted September 4, 2019 Report Share Posted September 4, 2019 If you can fit it in the amp's terminals! You might need reducers for that. Alternative, run the 1 gauge to the fuse holder, then 4 gauge out the other side of it to the amp (short distance between fuse holder and amp). Link to comment Share on other sites More sharing options...
corey0928 Posted September 8, 2019 Report Share Posted September 8, 2019 You can always use a lower fuse value on a wire but don't use a fuse rated at higher current than the wire. Link to comment Share on other sites More sharing options...
