Murky Posted August 22, 2019 Report Share Posted August 22, 2019 Yo i bought an earthquake mini d 2500 amp thought it was 0 awg input but it has only one 4 gauge input that has to be fused at 100amp This amplifier is supposed to output 2000w rms at 1 ohm and somehow 1800w rms at 2ohm Doesn't this mean i need like 18v to run this at full potential because it only has a 100a fuse rating I also have a kicker cx1200.1 that has the same fuse rating and 4 gauge inputs that does only 1200w rms at 2 ohm wich seems fair I feel like something might be wrong here Just tell me what i should do and if u have ever seen something like this (if the mini d2500 puts out 1800w rms at 1 ohm and does it without setting shit on fire i'll be happy) I'll be happy to hear from you guys Thanks in advance Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 22, 2019 Report Share Posted August 22, 2019 3 hours ago, Murky said: This amplifier is supposed to output 2000w rms at 1 ohm and somehow 1800w rms at 2ohm Doesn't this mean i need like 18v to run this at full potential because it only has a 100a fuse rating What is means is that the manufacturer lied about how much power its amp produces. It it puts out 1000 watts at 1 ohm you will be lucky. Its not physically possible for it to put out anywhere near 2000 watts on a 100 amp fuse. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Murky Posted August 23, 2019 Author Report Share Posted August 23, 2019 16 hours ago, Triticum Agricolam said: What is means is that the manufacturer lied about how much power its amp produces. It it puts out 1000 watts at 1 ohm you will be lucky. Its not physically possible for it to put out anywhere near 2000 watts on a 100 amp fuse. That seems kinda fcked up I better send that POS back You got any other recomendation for an amp at 2k rms at 1ohm? (probably won't be able to find it in europe tho) Otherwise i'll probably go with a ground zero if they put reliable power ratings on their products And thanks for saving me from a headache i apreciate it Link to comment Share on other sites More sharing options...
XSVTOYZ Posted August 23, 2019 Report Share Posted August 23, 2019 sound qubed , skar audio, sundown 3 brands here thatI know have you tube vids too Link to comment Share on other sites More sharing options...
