Second battery, capacitor or neither?
Adding a second battery is adding another tank of juice, and the load will be shared among the batteries. All you need to do is plug them into a charger once in awhile, because the alternator isn't going to keep both batteries charged while you're hammering on your system.
But like Ky said, if the drop isn't that bad you don't really need to add anything. You might want to put your starter battery on a charger once in awhile though. Just watch your voltage and if you see drops below 12 definitely charge up.
I wouldn't sweat your current voltage, honestly. 12.7? You're fine.
If you're itching to spend cash on an upgrade, 9 times out of ten, your best value and performance will be from an alt
  • Who's Online   1 Member, 0 Anonymous, 1456 Guests (See full list)
