proper wattage for running components active
Toomanyhobbiesjosh
I am installing type r alpine 6.5” components in my front doors and running dsp and full active. Sound deadening both inner outer, closing all openings off. Right now I am trying to choose the amps and my question is what wattage do I send to the tweeter on full active? Type r Rms rating is 100watts for the combo going thru the passive crossover, so I am planning on 100 watts to the 6.5” and I am stuck on what to do for tweeter. Have searched specs several times and also reviewed archived threads with no success. This is my first full active/dsp set up and it’s in kind of a hobby vehicle that’s not my daily driver so not going crazy with 1000$ plus mids in case I screw it up.
Any input would be greatly appreciated.
43 minutes ago, slowfkncar said:
In active with those, i don't think id go beyond 50w with the tweets or 150w per mid, you might need to dial down the tweets depending on your taste.
Not totally true. Ot all depends how you tune the amp    there are guys which I know who are running a zapco 150.6  bridged on a set of tweeters.  Another is running a set of tweeters off of a tru tech billet 4 bridged which is 300 watts.  It's just all on how you set the gain.  Usually in that case -10db will work awesome
Well, i cant argue that... I run 800rms to a pair of 7" mids and 300 rms to a pair of 1" tweets going for years without issue so yeah, with common sense it will work but i dont think the op wants to go overkill with a pair of 6" type r's.
41 minutes ago, Toomanyhobbiesjosh said:
I figured the tweets were gonna have to be dialed back. I have an alpine pdx 4.150(150 watts x 4 at 4 ohm) I was thinking of using, but seems like way too much for tweets. My only other amp is a Fosgate t400-2 (2 x 120 watts at 4 ohm). Either amp is too big for the tweets. Time to go hunting for a tiny 2 channel
Like tonasty pointed out, you could get away with the alpine or rf power for your tweets, of course the gains would need to be set to prevent driver fatigue with the tweets.
I’ve always been one to run the same amount of power to each driver. Hence running 150w per channel to my active 2 way setup.
  • 2 months later...
  • Who's Online   0 Members, 0 Anonymous, 1780 Guests (See full list)
