Boone
4F8BFA6B-9105-489D-A220-D8647AFE34DD.jpeg.f3aa4c8c63b201994429e03df434b283.jpegHello, all looking for some advice on a setup going in a project car 1998 Mitsubishi 3000gt hatchback.
Pioneer Avh x4800bs Hu - internal amp (14 watts RMS CEA-2006/50 peak x 4 channels)
Pioneer DM 9705 - 5 Ch class D
  • Continuous Power (RMS) Output at 4 Ohms75W x 4 (Main channel)
  • Continuous Power (RMS) Output at 2 Ohms100W x 4 (Main channel), 600W x 1 (Subwoofer channel)
RF P3D4 12 - 600 watts rms at 2 Ohms going in this enclosure above gonna add another later on with another amp. Using all Knukonceptz ofc power ground speaker wire & rcas.
Already have these above looking at replacing the 6x9s & the 6.5s. Factory area for the 6x9 has a port never seen this BDF6B21D-E5F8-4722-8939-15476333DBC8.jpeg.b5244cd6977a5cd8d2849624e4e46fb1.jpeg
Budget is for replacing these is $300-$500491FCAB2-B2C2-483A-8894-F95514A08CBF.jpeg.db2c63cc451d99d14be8221a5c604a18.jpeg2810277E-C03E-4E6D-B0D4-73D648C3F053.jpeg.87fb282032c935dbc7ab0110ad891fcd.jpeg
Been thinking about maybe putting in 1 set of 5.25 comp or 6.5 comp upfront 6x9 or 5.25 in rear side panels. looking at
Cerwin Vega stroker pro cvmpcl6.5
RF pro pps4-6.5
Alpine R
Your deck is active 3way capable.
As recommend to me, run your front comps active and ditch rear speakers or run a second set of comps on deck (which will be in networking mode as well. The front channels will be tweeters and rear the mid range midbass freqs.  Your front RCA will be Tweeter freq, and likewise rear RCA will be mid bass mid-range freqs. Sub RCA will be sub still.
You will have no need for rear drivers in that vehicle considering the sub bass you will possibly have with that pic of your enclosure.
I'd find a beefy 6.5" driver for the front doors and a pair of large format tweeters for high range. Active on 5 channels, call it a day ...
Any suggestions looked at so many speakers was making a list but phone died and didn’t mean 2 post this yet.
been a idea since the rear speakers are maybe a foot and half from me
I’m sponsored, can’t recommend stuff. Sorry, good luck
Thank you for the advice I appreciate your input makes sense 2 focus a lot up front is there a hz freq response and signal to noise u could have me look for maybe
5 minutes ago, ToNasty said:
For speakers.  What's the budget? Also where will the tweeters be placed because some tweeters do well off axis and some dont.  Theres a few things to think about when choosing components
3-5 not sure about tweets placement yet
1 hour ago, ToNasty said:
If you can raise it about 100 or so  the Stevens audio sa6.5 active set is probably my favorite set at this point.  Those tweeters do well on and off axis
Thank you have seen those in no rush gonna hand this car down 2 my newphew when he goes 2 college might have 2 save bit more
  • Who's Online   0 Members, 0 Anonymous, 1381 Guests (See full list)
