akuma4u Posted December 10, 2019 Report Share Posted December 10, 2019 Hey i got a buddy selling obsidian audio oa 12s d4s for cheap. He says they are basically sundown sa12s. The com0any went out of biz years ago so hard to find info on them. they are d4 subs. They are rated for 600rms but can take considerably more. I was able to find ts params on d2s. I want to run 2 in a sealed box off 2000rms. What i need to know is what would the f3 (how low the box will play before losing 3db) be in a sealed box. If its too high i wont bother. The box will be about 2.8 net here are the ts params for the d2s..can someone pls help me out and find of the f3 in a sealed box for dual d2s? Thanks! Product: 1 Obsidian Audio OA-12 Dual 2ohm 2. Specs: Obsidian 12" D2: Re: 4.0 Ohm Fs: 33 Hz Qms: 5.21 Qes: 0.56 Qts: 0.51 Vas: 34.4 Le: 2.21 mH BL: 19.1 SPL: 85.4 dB Sd: 490 cm^2 Mms: 243.1 g Xmax: 20mm Peak-to-peak: 62mm (2.45") Power Handling: 600 watts RMS Recommended enclosure info: Sealed ~ 1.0 to 1.5 ft^3 Ported ~ 1.75 to 2 ft^3 @ 30 to 35 Hz Link to comment Share on other sites More sharing options...
CstrokerV Posted December 10, 2019 Report Share Posted December 10, 2019 They are not basically SAs they had weak motors if I remember right. And if I recall only way to get f3 is to actually measure the subs in a box my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
akuma4u Posted December 10, 2019 Author Report Share Posted December 10, 2019 14 minutes ago, CstrokerV said: They are not basically SAs they had weak motors if I remember right. And if I recall only way to get f3 is to actually measure the subs in a box Hmm..i was told by seller they are designed after the sa model and obsidian audio WAS created by sundown audio.. hard to get info on out of business subs. Link to comment Share on other sites More sharing options...
CstrokerV Posted December 11, 2019 Report Share Posted December 11, 2019 They where if I recall still wasn’t basically a SA and their are threads on here about them do a bit of searching in the site my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
ToNasty Posted December 11, 2019 Report Share Posted December 11, 2019 Great subs. I had a bunch of them. ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
akuma4u Posted December 11, 2019 Author Report Share Posted December 11, 2019 2 hours ago, ToNasty said: Great subs. I had a bunch of them. Thanks for the help Link to comment Share on other sites More sharing options...
ToNasty Posted December 11, 2019 Report Share Posted December 11, 2019 You.need to model it. No one can tell you without having it modeled ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
akuma4u Posted December 11, 2019 Author Report Share Posted December 11, 2019 54 minutes ago, ToNasty said: You.need to model it. No one can tell you without having it modeled Yes thats why im looking for someone to model it for me 2 12 d2s off 2krms in a 1.8net sealed enclosure Btw i wasnt being sarcastic when i said thanks for the help. You said they are great subs so that helps. Link to comment Share on other sites More sharing options...
YukonXL04 Posted December 11, 2019 Report Share Posted December 11, 2019 10 hours ago, akuma4u said: Yes thats why im looking for someone to model it for me 2 12 d2s off 2krms in a 1.8net sealed enclosure Btw i wasnt being sarcastic when i said thanks for the help. You said they are great subs so that helps. Your probably going to have to provide ts specs to model with. 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed Link to comment Share on other sites More sharing options...
akuma4u Posted December 11, 2019 Author Report Share Posted December 11, 2019 1 hour ago, YukonXL04 said: Your probably going to have to provide ts specs to model with. I already did that in my first post. Link to comment Share on other sites More sharing options...
