Gerardo medina Posted January 13, 2020 Report Share Posted January 13, 2020 I want advice on what amp for 3 Rockford p3 10s .. wether a t1000 or t1500 ? Any advice ? Thank you Link to comment Share on other sites More sharing options...
bcbrassard Posted January 13, 2020 Report Share Posted January 13, 2020 My T1500 birth sheet was 1229 watts @ 4 ohm, 1712 watts @ 2 ohm & 1945 watts @ 1 ohm. IMO you want to be looking for a amp that puts out good numbers @ 2 ohms. I think 1500+ watts intp 3 P3 10's is about right. Set the gains properly and don't over push them and they should be solid. Link to comment Share on other sites More sharing options...
Gerardo medina Posted January 13, 2020 Author Report Share Posted January 13, 2020 Yeeeee 😊 thank you Link to comment Share on other sites More sharing options...
bcbrassard Posted January 13, 2020 Report Share Posted January 13, 2020 The T1's are great amps. A bit on the expensive side though. A lot of good amps to choose from out there. Link to comment Share on other sites More sharing options...
Joshdashef Posted January 14, 2020 Report Share Posted January 14, 2020 Closest to that would be a DC 2k / cresendo 2k / etc. around 100-200 less than the T1500 However, none of these have the BD-CP tech of the Rockford one, meaning the power deliver at 2 ohms is similar to 1 ohm. SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
