22 minutes ago, bcbrassard said:
Thank you sir.  You could do a baffle on the inside of the enclosure.  You are definitely on the right track with the bracing.
With this enclosure i build i had to take the back panel of the trunk trim & the latch off to get it in and out. just a suggestion.
yeah i thought about taking those out. ordering a SMD terminal, so i can wire 2ohm and .5 easier, cause this thing is a TIGHT fit. whats urs tuned too again?
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
320a Brand X Purple Metallic Ho Alt
125+ Ft of oversized 1/0
  • Replies 62
  • Created
  • Last Reply
My enclosure i a Joe X design( member on here that helped others)  Tuned to 33 hz, i listen to a wide verity of music and now into SQ instead of SPL.  My build log is on here 2012 Malibu build, check it out sometime.  I am doing layout on plywood for Spare tire battery tray(limitless Lithium 25 ah $900 battery with a XS Power D3400 upfront, stock alt @ 150 amps but will upgrade this summer)  I spent $7k last summer buying up tools, wiring, Leds , DSP,  HU,  ect.
I too have the SMD speaker terminal,  subs @ 1 ohm.
was thinking about getting that d3400. for the back and putting the d1200 under hood.
i did just order this tho https://www.wccaraudio.com/mini-bass-meter-2.html
and https://www.wccaraudio.com/2-channel-terminal-grade8.html
also placing my order for the HO ALT right now.
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
Damn those SPL meters are spendy, That SMD speaker terminal is nice and at a super good price point.  Now do you have a way to set your gains properly?  SMD DD-1+  is the best tool IMO  I bought my back in 2012 for setting gains in my Lancer build .
I have a clamp and multi-meter tthat dd-1 tho is pretty nice!
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
Couple quick pics of that build. It's my work car.
Front Stage.  8" p3 subs in the kicks for midbass & 2 T2 6.5" midrange, w/ a T3 tweeter.
Substage: 2 Sound Qubed HDS 310"s  1200/2400 max on wattage.
2 Kenetic Energy 1800 battery's w/ a Singer 220 amp alt.
I was running RF Power Series amps, but i pulled them for the Malibu(T1500.1 & T1 400-4)  These are budget friendly Sound Qube amps(2250 watts on subs & 850 for 8" in kick panels up front.
I swapped out my Power Series amps for Punch Series,  These are raised up 3/4" from the floor for cooling & spills. 2 P500-4's
Rear fill speakers are now RF T1 6.5"( i will never do amplified rear speakers again, not work the expense)
The power plant to run the stereo system lol.
I got a couple but like you said you can't really get a feel of the sound.  It gets loud as fuck. This car is deadened about 85% but not as good of materials.
Little update while stuff is being made/transit. Went and got some Wrap for the box.
Will match the Alt perfectly! :D can't wait
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
 Flex https://imgur.com/gallery/U1gHCYX
Gf texted and said the vagina model, was rattling and doc was complaining to nurses not knowing what it was if was their heater acting up lol a old man walls by when I turned it down and goes, ayeeeee turn it up and started dancing lmao 🤣👍💪
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
  • Who's Online   0 Members, 0 Anonymous, 291 Guests (See full list)
