neralin Posted January 31, 2020 Report Share Posted January 31, 2020 Every time I try a new windows update section it gives me a different error code. Last time it was WindowsUpdate_80244010 error. I've tried the MS WindowsUpdate.diagcab. Also sfc /scannow said it has a problem it didn't fix. What can I do now? Got the solution- https://appuals.com/windows-update-error-code-80244010/ Link to comment Share on other sites More sharing options...
Joshdashef Posted January 31, 2020 Report Share Posted January 31, 2020 6 hours ago, neralin said: Every time I try a new windows update section it gives me a different error code. Last time it was WindowsUpdate_80244010 error. I've tried the MS WindowsUpdate.diagcab. Also sfc /scannow said it has a problem it didn't fix. What can I do now? OS version? Components? Have you done any bios flashes recently or at all? SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
