Scotnemily Posted February 21, 2020 Author Report Share Posted February 21, 2020 Yeah I know kerfs do work, but another thing I was worried about was the edge showing through in the kerf. some times you can see the lines through the kerf. It might not show under the vinyl, but then again it might. I almost bought these before anyway, so this time I decided to give them a try. Might need to build 2 boxes and sell one if it performs well. That way I can recover the cost of building the 1st one Link to comment Share on other sites More sharing options...
Scotnemily Posted February 25, 2020 Author Report Share Posted February 25, 2020 Smart corners came in the mail today. I wont get a chance to try them out for a few days. they look nice though. I have everything I need to finish the box except time. Swapped at work so no lunch breaks for now. Link to comment Share on other sites More sharing options...
Scotnemily Posted February 26, 2020 Author Report Share Posted February 26, 2020 I got home from work tonight about an hour early. I decided to take advantage of that time. nothing exciting, but here are the parts traced out on the boards. and here they are rough cut with the jigsaw. I needed 12. I will still need one 1/2 inch, but I am out of that size mdf. that’s all for tonight. Link to comment Share on other sites More sharing options...
ehall8702 Posted February 26, 2020 Report Share Posted February 26, 2020 That's alot of cutting, I was looking at those corners after u told us about em and thought the templates would be an awesome idea , All except the cutting lol. I'm not a carpenter by far, and definitely don't have the patience to but all those out.looks good tho can't wait for test run of those vfls. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Scotnemily Posted February 26, 2020 Author Report Share Posted February 26, 2020 Yeah it is a little time consuming. I spent about 45 mins tracing them out and rough cutting them. I figure it is going to take another 45 mins to run them on the router and attach them to each other. I am going to use the method Mark demonstrated. glue and nail each to the bottom of the one just cut as you go. this make since to me. Link to comment Share on other sites More sharing options...
Scotnemily Posted March 2, 2020 Author Report Share Posted March 2, 2020 Almost no time to work on the box yet. I did get this done today. Link to comment Share on other sites More sharing options...
ehall8702 Posted April 1, 2020 Report Share Posted April 1, 2020 Any updates on Chuck's box??? I got mine in and fired up, figured you would have beat me to it! Definantly looking forward to seeing another awesome box from u man. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Scotnemily Posted April 3, 2020 Author Report Share Posted April 3, 2020 Sorry have not had anytime to work on it. I hate that everything is just sitting there waiting on me. As soon as the weather permits, have to do valve cover gaskets, upper timing chain cover gaskets, and upper and lower control arms on the car. Then I can move back to the box. 😔 Link to comment Share on other sites More sharing options...
ehall8702 Posted April 4, 2020 Report Share Posted April 4, 2020 On 4/3/2020 at 6:23 AM, Scotnemily said: Sorry have not had anytime to work on it. I hate that everything is just sitting there waiting on me. As soon as the weather permits, have to do valve cover gaskets, upper timing chain cover gaskets, and upper and lower control arms on the car. Then I can move back to the box. <img src="> Yeah I know how it is, sucks to look at that stuff half done and taunting you! Hope to see you get back to the "important" shit soon lol 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Scotnemily Posted April 4, 2020 Author Report Share Posted April 4, 2020 Thanks. I was hoping to work on the car today, but crappy weather. Maybe tomorrow... Link to comment Share on other sites More sharing options...
