Need Help with relay
So i have an older Python alarm / remote start I think its a 5906 or 5606P ? Anyway had a bad mishappy the wiring harness got caught in the steering intermediet shaft cutting wires
I have been rewiring the left side of the dash sure to the puff of smokes that that puffed up. anyway i got everything working but the remote start.
so it will crank but wont stay running, till i find this  board level soldered relay ? I have attached the picturee so after figuring out that this was the wires that is placed around the Key cylinder what i cant figure out is what do  you connect the red and the red/blue wire. I am guessing that the red +12/batt and the red/blue is +12 ignition on??
can anyone help me with this.
the Vehicle is a 2001 Lincoln Town car.
thanks for the help in advance.
Ric
15 hours ago, slowfkncar said:
Red - 12v  (1A fuse)
Blue - negative (gnd) status output from alarm (grounded during remote start, usually a dark blue or blue from Brian)
thank you very much sir.
  • 1 month later...
well finally getting time to mess with this, I cant seem to get it to  work and help stay running its a security issue, cause the PATS system on  FORScan showing a code for no key..
I am at a lost think i might have to rip it all out and start over .
Take a read at that PDF below bro, could be a bad relay or someone might have hit the key limit (4) which wipes the last known key ID, also make sure nothing moved by the immobilizer ring.
It's a simple system, relay clicks on during RS command and sends the programmed code to the ring on the cylinder.
n555f.pdf
Great!
An automotive enthusiast.
https://autance.com/
  • Who's Online   0 Members, 0 Anonymous, 1509 Guests (See full list)
