Low level output 0.4V? Do I need to fix this?
So using stock head unit on Dodge Journey.
I have tried two different line output converters and both are only putting out 0.4 Volts. (levels turned to max) I thought this was supposed to be closer to 2-5 volts.
Is this a problem? Is my amp getting enough signal? Is this something I should worry about?
Thanks,
That could very well be the problem then, though not knowing what LOC you are using, it could also be that.
https://www.dropbox.com/sh/qm8w9d5ydn0ucdt/Pzr8B6LlYw/Snow's DD-1 Tracks.zip
You can find a 40hz -0dB track there.
As for line out converters, most a junk, poor quality, and will create distortion in your signal. Rockford might still offer one, otherwise I'd recommend audiocontrol if quality is important to you
If all you need is two channels, then yes. They have larger models if you require more channels. If you're just adding a sub stage though, that one will be perfect
  • Who's Online   0 Members, 0 Anonymous, 616 Guests (See full list)
