Alt upgrade .. Make a difference .yes or no?
8 hours ago, BMG18 said:
I would like to put the 270 or 300 alt in unfortunately I'm very limited on what i can work with.. it's a 98 4 runner that came with stock 70amp and noone makes them unless it's special order which for some reason almost double the cost of other H.O. alts .so i did the cs144 swap out of a 95 cadillac .. Its the same mounting style as Toyota  Its suppose be 140 amp but I've never seen those numbers.. and as for the same year & STYLE CS144  I've only seen up to 220 or maybe 250 and for only around $300 or less ... I appreciate the info tho . Makes sense when it's broke down
Do you know if that alternator will fit a 95 land cruiser? I am having the same issue finding a bigger than 80 amp alternator...
You've emailed all the companies and asked?
Just because they don't list it, doesnt mean they won't make it, goodluck!
On 4/1/2020 at 10:32 PM, BMG18 said:
The yellow top came with truck but ive learned they turned to sh*t when they left USA.. don't know how old it is but I've had for 3 years.. i use a meter off of my obd2 program . Which given it prolly has couple millisecond lag but i haven't personally seen it drop below 12.8 maybe and that's long bass note.
I'm trying keep it in the $400ish range.. Found 220 alt for $250 and i Kno the battery runs under 400 i just wouldn't sure if it was needed or if i would benefit sound wise... Thanks for advice
You didn't find a 220 amp alt for 250. You found the eBay Chinese junk for 250.
You can get a great alt from brand x. 250 amp (180-190 @ idle/ 280 at 2250) shipped to you for about $305.
Find em on Facebook
Brand x will build you anything for any car
As far as alt size goes, the smaller the engine and bigger alt , the engine has a hard time dealing with the increased drag.
My 250 amp gives my 2.3l a run for it's money at stop lights
On 4/5/2020 at 10:38 PM, Ipoksmote said:
Well bro I can tell you I have a new 200A iraggi alt coming sometime this next week.
I'll let you know if I notice a difference .
Definitely let me Kno .. I'm curious as FK.. they have it on there site or u have to call to get it special made
If your car takes like 90-130 amps to run all its usual stuff then you only upgrade to a 150 or 200 amp alt then your only really gaining 60-110 amps theoretically speaking. That's why you always try to get the biggest you can go, and never go with some no name ebay shit that claims big numbers.
On 4/5/2020 at 6:29 PM, 1.21gigawatts said:
I would get a 370 or 390 to have head room if you can afford it. Or you can get a dc 270. Email singer, ces, mechman, JS, and iraggi too.
Did Iraggi finally come back around? I know they were having issues left and right
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
  • Who's Online   1 Member, 0 Anonymous, 1632 Guests (See full list)
