Dragonware Posted May 13, 2020 Report Posted May 13, 2020 Hi Guys so we all know what these two are used for did I waste my money ? Plan on using Taramp HD3000.1 for my subs Taramp DS800X4 for my doors The DS800X4 only has a switch High, Low pass or Full Range. No crossover settings to fine tune. - CC1 not needed correct ? The HD3000.1 also only has Highpass 10hz to 80hz and a Low Pass of 80Hz to Full Confusing ?? Besides setting gains is the CC1 useful to me in any way ? Quote My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top
BassMunky Posted May 13, 2020 Report Posted May 13, 2020 Wth why wasted money Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
CstrokerV Posted May 13, 2020 Report Posted May 13, 2020 for the 3000.1 yes you can use it no on the other one if its just switches ... why you would buy a class d for mids and highs is beyond me and not research the amp before buying it to see if it has variable xover points Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
