1point21gigawatts Posted May 28, 2020 Report Share Posted May 28, 2020 13 hours ago, jessdabest77 said: Hey guys, I've been thinking a lot about my build and here's what I'm thinking. It's a 2003 Chevy S10 Xtreme ext.cab and subs are two 15" FI SP4's v1. I'm thinking of doing a 4th order box, not walling it so that's why I need help. What size box, port size, running, and placement of port, up, forward, or side? I'm running 7 k amp power and good electrical. Any advice, suggestions, and help would be fantastic cause I am lost. Measurements of available area for enclosure? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
CstrokerV Posted May 28, 2020 Report Share Posted May 28, 2020 3 minutes ago, 1point21gigawatts said: Them subwoofers have an 11” depth and no vent pole. I might be able to design a wall, subs forward, port side. Maybe. I need exact measurements. He doesn’t want a wall he should be still be able to do subs forward and vent side under window line my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 29, 2020 Author Report Share Posted May 29, 2020 Hey guys,ok so I did a rough measurements and got 46" wide x 17" depth x 22" height. I might be able to gain a few inches in width if I remove 3rd seat which I wouldn't mind doing,cause it won't be needed anyhow. The 4th order does sound really good but if I went that route I'd do some type of wall instead of cut through. If perhaps I can see both types of designs that would help me in decide what I can do. If I can get this to be able to play real low and get loud,I'd be more than happy.Thanks for all the help Link to comment Share on other sites More sharing options...
Joshdashef Posted May 29, 2020 Report Share Posted May 29, 2020 1 hour ago, jessdabest77 said: Hey guys,ok so I did a rough measurements and got 46" wide x 17" depth x 22" height. I might be able to gain a few inches in width if I remove 3rd seat which I wouldn't mind doing,cause it won't be needed anyhow. The 4th order does sound really good but if I went that route I'd do some type of wall instead of cut through. If perhaps I can see both types of designs that would help me in decide what I can do. If I can get this to be able to play real low and get loud,I'd be more than happy.Thanks for all the help With those measurements you get about 10 gross cubic feet. That does not account for the thickness of material, double baffles, bracing, subs, port, etc. If you want to have a box without a wall you have to go to just a ported box. If you are willing to do a wall you could probably fit in a small 4th order SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 29, 2020 Report Share Posted May 29, 2020 1 hour ago, jessdabest77 said: Hey guys,ok so I did a rough measurements and got 46" wide x 17" depth x 22" height. I might be able to gain a few inches in width if I remove 3rd seat which I wouldn't mind doing,cause it won't be needed anyhow. The 4th order does sound really good but if I went that route I'd do some type of wall instead of cut through. If perhaps I can see both types of designs that would help me in decide what I can do. If I can get this to be able to play real low and get loud,I'd be more than happy.Thanks for all the help I’ll design you one after I get some rest. You might have to remove the front seats just to get the enclosure in and then put the front seats back on. I’ll know more once I start designing. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 29, 2020 Report Share Posted May 29, 2020 28 minutes ago, Joshdashef said: With those measurements you get about 10 gross cubic feet. That does not account for the thickness of material, double baffles, bracing, subs, port, etc. If you want to have a box without a wall you have to go to just a ported box. If you are willing to do a wall you could probably fit in a small 4th order He won’t be able to run a 4th order enclosure in that cab. Not even a 1:1 ratio. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
CstrokerV Posted May 29, 2020 Report Share Posted May 29, 2020 6 hours ago, 1point21gigawatts said: He won’t be able to run a 4th order enclosure in that cab. Not even a 1:1 ratio. if he walls it he should be able to do a forth those measurements are under window line my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 29, 2020 Report Share Posted May 29, 2020 1 hour ago, CstrokerV said: if he walls it he should be able to do a forth those measurements are under window line I did think that height was short and when I read that I was like, wtf? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 29, 2020 Report Share Posted May 29, 2020 10 hours ago, jessdabest77 said: Hey guys,ok so I did a rough measurements and got 46" wide x 17" depth x 22" height. I might be able to gain a few inches in width if I remove 3rd seat which I wouldn't mind doing,cause it won't be needed anyhow. The 4th order does sound really good but if I went that route I'd do some type of wall instead of cut through. If perhaps I can see both types of designs that would help me in decide what I can do. If I can get this to be able to play real low and get loud,I'd be more than happy.Thanks for all the help Did you measure the height from floor to ceiling? If not, then I need that measurement. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 29, 2020 Author Report Share Posted May 29, 2020 Ok, if I go all the way up to ceiling from floor, I get 35". Same width and depth. Now if I can see both design's. Perhaps 4th ordered. But I'd like to see ported and 4th and your thoughts and suggestions would be great. I appreciate your help and knowledge. Link to comment Share on other sites More sharing options...
