Skar Audio Subs Weird Noise
Box is about 2 cubic ft sealed before the subs are loaded. I thought they were bottoming out as well, but why on earth would a sub bottom out at like 60hz? I'll check the spiders as soon as possible. Gain was set about a 1/3 of the way which was about 8dB of overlap. it's since been turned down to avoid the noise.
Is your voltage way low since you said it only happens at fully turned up witch would cause a lot of distortion. I would try running 1 sub at a time and see the difference.
And that subwoofers surround is wrinkling which is kind of telling me it might be bottoming out. The amp isn’t enough to do that and the gain isn’t high enough to distort it too much and the volume isn’t high enough. Did you check the other subwoofer and did you check the spiders? Is it just that one subwoofer? I think the spiders are messed up, disconnected somewhere causing the subwoofer(s) to bottom out and/or make noise.
:guido:
4 minutes ago, Jonrussell18 said:
After talking with Skar, we will be sending the subs back for a full refund. Now the debate is getting another pair of SDR 10s or swapping them out with something different. Any suggestions? Box is 2 cubic feet sealed, amp is an RP1200.1d.
Alpine type R’s
:guido:
Thats crazy both were defective. At least skar promptly made it right. You could look at ct sounds tropos. Or some american bass tnt 10s. Also the new audio legion brand had some decent lookin stuff in their lineup.
you can check out american bass es1044 's heard the redesign has been good on them
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
  • Who's Online   0 Members, 0 Anonymous, 1190 Guests (See full list)
