Killjoy Posted June 16, 2020 Report Share Posted June 16, 2020 So I have 2 18 in competition kicker l7 and want to know what the best amp to use is and will a head unit with 50 watt max output be able to power it Link to comment Share on other sites More sharing options...
Joshdashef Posted June 16, 2020 Report Share Posted June 16, 2020 2 minutes ago, Killjoy said: So I have 2 18 in competition kicker l7 and want to know what the best amp to use is and will a head unit with 50 watt max output be able to power it The RCA coming out of the headunit goes into the amplifier. It will power any amp. However. The headunit/radio it self has an amplifier built into it that outputs a set rms rating which can go directly to a speaker, not a sub, and power it just fine SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
