Recommendations for system with stock electrical and this box.
You rock, thanks man! And that looks like a very easy way to set the gain correctly and avoid clipping.
I used a multimeter when setting the gain on the amp i have now, did 500 watts times 1 ohm, squared, and then got as close to 22.3v as i could. The little bass remote with this amp has a little light that shows when the amp is clipping, and it still quickly flashes for a split second on the very deep bass hits, and mostly when under 35hz.
I will measure under my seat, but hopefully 2.5" will still be fine.
You are welcome! And that’s dope that the bass knob has a clip meter. And really it was Ron that found you a spot on amp for them subwoofers. I didn’t do anything but add in some commentary and information to make you secure with that.
:guido:
You both are very helpful. Much appreciated.
And according to that video you posted with the dimensions, the sundown also has a clip meter. But using the capacitor might be a better indicator, as it will make sound when the clip is a steady clip. And the lights on the knobs flicker when any clip starts. I talked with Digital Designs and they told me not to worry if the light is only flickering for a second, there is nothing to worry about unless the light stays on for a couple seconds straight.
And that amp will definitely fit at 2.5". There will still be some room for it to breath as well.... Plus i have AC floor vents under there beside where the amp will go. That should also help keep the amp cool.
Now to decide where to get this amp from.
Oh i know, i watched it when you first posted it. A cap inline with a speaker. Easy enough!!
I replaced all the mids/highs in my vehicle so have plenty of cheap speakers sitting around to use. I will order a couple of those caps. As cheap as they are id rather get a couple... Just in case...
Read the comments in the video specifically Tony D’Amore ...further more you don’t set amps at clipping you do it at 1% t.h.d which the video didn’t show or pay any attention to where it was and what the speaker did if anything
  • Who's Online   1 Member, 0 Anonymous, 1305 Guests (See full list)
