Backwoods Posted June 25, 2020 Report Share Posted June 25, 2020 Mods include magnaflow exhaust, full suspension lift with 33" tires and new wheels, BMC, bumper trim, full weld on sliders, skid plates, dark tint, blacked out emblems, LED interior lights and a few other odds and ends. But what y'all care about here more.... Kenwood excelon DMX907s headunit with idatalink maestro. double USB input replaced stock USB/Aux input. All doors and rear hatch speakers replaced with Kenwood KFC series speakers. DDaudio 10" (entry level 200 series) subs in the back with a DDaudio 500 watt rms amp installed under front passenger seat. Bass remote installed in the worthless cubby hole on dash. Stinger X, 4ga ultimate wiring kit and stinger 4000 RCAs. Quick disconnect added to subwoofer box with an XT60 connector. Makes removal quick and easy for when I need all the cargo room. UPDATE, New setup Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
Ron36 Posted June 25, 2020 Report Share Posted June 25, 2020 Clean audio build. I’m sure it sounds good I know U want more but it looks very clean. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
Backwoods Posted June 25, 2020 Author Report Share Posted June 25, 2020 2 minutes ago, Ron36 said: Clean audio build. I’m sure it sounds good I know U want more but it looks very clean. Thanks man. Keeping everything clean looking inside is important to me. And yes, I'd like a little more. But want to keep the same box and amp location. I'll likely be ordering the sundown sfb 1000d soon. And if the subs I have now can't handle that, I'm thinking maybe the sundown E series 10s might be good fit with that amp. But I'll try the DDs for a while first. Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
Backwoods Posted June 25, 2020 Author Report Share Posted June 25, 2020 In my garage/man cave... And @Ron36 I read on another post that you're a technician... So you might like the second picture... A buddy of mine cut that out with his laser for my garage bar. Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 25, 2020 Report Share Posted June 25, 2020 The car audio build is clean, for sure. But what I like, is the garage. It’s nice how it is but has so much potential. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
Backwoods Posted June 25, 2020 Author Report Share Posted June 25, 2020 17 minutes ago, 1point21gigawatts said: The car audio build is clean, for sure. But what I like, is the garage. It’s nice how it is but has so much potential. Thanks. It's wired for a 2 post lift, and a welding station... And concrete is reinforced for the lift as well... But I never got around to setting up either. The wife and I are debating if we plan on moving one more time or staying here forever. I don't want to get it perfect and then we move LOL Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
LT.Smoke Posted June 25, 2020 Report Share Posted June 25, 2020 Nice vehicle,Install and most of all garage:) Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌 Link to comment Share on other sites More sharing options...
Backwoods Posted June 25, 2020 Author Report Share Posted June 25, 2020 Thanks fellas. I love the garage. Just had it built last August. Been wanting one for years. The SFB1000D has been ordered. And I've been debating between the sundown 10" E series (500rms each) or the SA series (750 RMS each) to go with that amp if I decide to switch subs. The SA series obviously look better, but they'd be underpowered. The E series would be better matched up with RMS, but not as good of subs. But the question is, would the underpowered but higher quality SAs still outperform the properly powered E series? Either way, they'll be in 1.5 cubed each ported and tuned to 30. So slightly bigger box than suggested, which is good for underpowered subs I believe.... Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
deathcards Posted June 25, 2020 Report Share Posted June 25, 2020 is it just me or does anybody else see a giant handle bar mustache on on these 4 runners btw clean build crap goatee i am dyslexic i feel its getting worse with age. skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 26, 2020 Report Share Posted June 26, 2020 7 hours ago, Backwoods said: Thanks fellas. I love the garage. Just had it built last August. Been wanting one for years. The SFB1000D has been ordered. And I've been debating between the sundown 10" E series (500rms each) or the SA series (750 RMS each) to go with that amp if I decide to switch subs. The SA series obviously look better, but they'd be underpowered. The E series would be better matched up with RMS, but not as good of subs. But the question is, would the underpowered but higher quality SAs still outperform the properly powered E series? Either way, they'll be in 1.5 cubed each ported and tuned to 30. So slightly bigger box than suggested, which is good for underpowered subs I believe.... I would get the sa’s for sure. They are built like tanks and in the future you you could put a sfb3000d on them, easy with no problems or worries. Them sa’s are the sh!t would still be hungry on that sfb3000d. But once you learn more then you can push the envelope a little more. Sundown subwoofers do better in larger enclosures and can still handle double or triple the rated rms in a larger than recommended enclosure. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
