1point21gigawatts Posted July 8, 2020 Report Share Posted July 8, 2020 “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted July 8, 2020 Report Share Posted July 8, 2020 https://www.parts-express.com/33uf-100v-electrolytic-non-polarized-crossover-capacitor--027-328 buy this capacitor and hook it to the positive terminal of the speaker or tweeter (distortion detector). “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
brennen.hall24 Posted July 8, 2020 Author Report Share Posted July 8, 2020 1 hour ago, 1point21gigawatts said: Buy a smd dd-1 or make a distortion detector. Yeah i think thats the best idea tbh thank you tho!! Link to comment Share on other sites More sharing options...
Backwoods Posted July 8, 2020 Report Share Posted July 8, 2020 1 hour ago, brennen.hall24 said: I just either set it too high where it'll clip my sub or too low where I'm not getting enough bass Ah yes... The age old conundrum. If you go directly from not enough bass into clipping it normally means it's time to buy more equipment Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
brennen.hall24 Posted July 8, 2020 Author Report Share Posted July 8, 2020 Just now, Backwoods said: Ah yes... The age old conundrum. If you go directly from not enough bass into clipping it normally means it's time to buy more equipment yeah i want a better amp thinking of going with a hifonics amp or sundown Link to comment Share on other sites More sharing options...
1point21gigawatts Posted July 8, 2020 Report Share Posted July 8, 2020 52 minutes ago, brennen.hall24 said: yeah i want a better amp thinking of going with a hifonics amp or sundown Hifonics after that good. They don’t do rated. Sundown are really good and do more than rated. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
brennen.hall24 Posted July 11, 2020 Author Report Share Posted July 11, 2020 On 7/8/2020 at 3:54 PM, 1point21gigawatts said: Hifonics after that good. They don’t do rated. Sundown are really good and do more than rated. I don't know i had a hifonics amp before that did more than rated Link to comment Share on other sites More sharing options...
1point21gigawatts Posted July 11, 2020 Report Share Posted July 11, 2020 28 minutes ago, brennen.hall24 said: I don't know i had a hifonics amp before that did more than rated Which hifonics amp? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
Backwoods Posted July 11, 2020 Report Share Posted July 11, 2020 Some of the hifonics amps from the late 80s and early 90s were straight up BEASTS for their era. I had an old school Zues from the 90s. I had the amp on 4 earthquake Magma 12s, the OLD ones with the flat cone. That system would POUND. Back then they were also going for about a dollar per watt too... Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
CstrokerV Posted July 11, 2020 Report Share Posted July 11, 2020 Where is you sub level at if it’s 0 turn it up my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
