akuma4u Posted July 12, 2020 Report Share Posted July 12, 2020 When buying an agm battery, which battery specs are most important? Cca hca ah? I was told ah is the main thing the higher the better. But then i was told its all about how many amps it can produce..the higher the better.. so should i be looking at the ah cca or hca?? Thanks Link to comment Share on other sites More sharing options...
Backwoods Posted July 12, 2020 Report Share Posted July 12, 2020 Will the battery only be a secondary battery or will it be your starting battery under the hood? If it's just a secondary battery, AH is what I'd be looking at. As it will be used for reserve capacity. Starting batteries need cranking amps, cold cranking/hot cranking. So CCA and HCA will play a bigger role. Singer 250amp Alt, Singer PCM bypass harness Titan8 Lithium Underhood safe BCI PWR-S5 Big 3 W/ dual runs of power/ground. All 1/0awg OFC SounDigital EVO 5K amp, Two 15" Fi SSD subs Next Level Fabrication @ 7 cubes net, tuned to 32HZ Link to comment Share on other sites More sharing options...
akuma4u Posted July 13, 2020 Author Report Share Posted July 13, 2020 6 hours ago, Backwoods said: Will the battery only be a secondary battery or will it be your starting battery under the hood? If it's just a secondary battery, AH is what I'd be looking at. As it will be used for reserve capacity. Starting batteries need cranking amps, cold cranking/hot cranking. So CCA and HCA will play a bigger role. Its rear batt/secondary batt. Thank you for your reply. I will just get the biggest ah batt i can get for the rear. Link to comment Share on other sites More sharing options...
