How much port area on aero port 4th
Jonathan91v8
I just noticed you said aero ports. I must have over read that. But that doesn’t matter. On 4th order enclosures, there isn’t any aero port short cuts and using less port area like on regular enclosures. Any less port area doesn’t make bandwidth better like it does with regular enclosures, on 4th order enclosures using less port area minimizes output. A 4th order enclosure already has awesome bandwidth. You have to understand how the 2 sections work. You would have to use a 14 inch concrete tube to equal the port area needed for that enclosure and it’s not smart to use multiple aero ports on any application if you are thinking of that. So no, you can’t hit up any aero port companies to fulfill your needs on that particular enclosure build. And in aero ports 6+6 doesn’t equal 12, if you didn’t already know. And if you don’t want to use a 14” concrete tube, then do a square port 12”x12”(inner port measurements, NOT OUTER)=144sq” of port area. Or 11”x13” or 10”x14”. But no further apart than that in reference from straying away from a square shape. Closer to a square, the better.
:guido:
And since there isn’t flares on concrete tubes, you can’t use regular aero port calculators. You have to use a round port calculator. Because each flare adds an inch. Either port configuration you choose, this calculator would help you.
https://www.the12volt.com/caraudio/boxcalcs.asp
And if you do use a 14” concrete tube, remember that the port diameter isn’t actually 14”, it’s like 13.5”. The port would have to be about 12.5” long. That would tune it at 45hz.
:guido:
The aero port theory or formula or whatever you wanna define it as, doesn’t apply to bandpass enclosure’s front sections. And since it’s a 4th order bandpass enclosure, the front section is the only ported section. So the aero port formula doesn’t apply to a 4th order enclosure even if using an aero port. The front section always has to have a lot of port area, no matter the type or shape of the port you use on it.
:guido:
On that minimum rms you don’t want too big of a port area because it too would minimize the output. Tell me the measurements of the front board where the port goes. Don’t include the measurements of the surrounding boards if any of them overlap that board to add 0.75”. What are the measurement of the front board when drew up a cut sheet for that enclosure and cut that front board? So I know what the measurements of the port can be.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
