Been working on getting front fender wheel wells done, so i can add more wiring and fuses. Got pass side in/welded/bolted, bagged problems. Have to make mounts for the fuses, and computer. I also got a battery lug crimper. Thing works nice.
  • 6 months later...
So thee 2 15s are almost drowning the mids and highs. Waiting on the new Crescendo symphony amp to redo mids/highs. Also venturing in to lithium, built a 64ah lifepo4 headway battery for under $300.
Man! Building your own bank is definitely the way to go!
Just tested system with out the lithium and it wasnt dropping below 13. The 2 alts stock 145 and js alts 270 and 2 batteries are holding up. Now i still need to let it play for awhile, however the high/mid amp gets hot (cook food on it) class a/b wired to 2 ohm. Will test for longevity once new amp comes in. Will put new amp in and swap the sundown sbf 200x4 in the burb with the current hypnotic amp. Dafaseles i read in another thread you got daughters, i got 2 myself. I get some weird looks when im bumping bassed disney music with the eldest.
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
