Welcome to the SMD forum!
Sign in to follow this
SpaceKing
Dual input amp, both cables fused?
Fuse for the wire size, I’ve seen 300a on 1/0
‘16 ram. Net audio pac converter. Pac bass knob. fox acoustics sealed. 12” DC lvl 4 w/ blue carbon fiber cap. Shuriken bt-80. Stinger 1/0. Big 3. Taramps smart 3..... dual lvl 4 DC, 2 smart 3s in the works....
Share this post
Link to post
I was told by someone who talked to someone at Incriminator Audio about their IA30.1 which also has dual inputs and calls for a 400 amp fuse. What I was told was if you're using a fused distribution block, 2 200 amp fuses would work. If you're using an unfused distro block, use a 400 amp fuse before the block for a single amp. I would assume the BC-4k would be the same deal
  • Thanks (+1 Rep) 2
Share this post
Link to post
4 hours ago, SpaceKing said:
Thanks Dafaseles. I appreciate it.
Yessir!
Share this post
Link to post
