BassMunky Posted September 15, 2020 Report Share Posted September 15, 2020 How i know the speaker blown? I pushed on the cone of the pro 6 5 mid and it will play. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
1point21gigawatts Posted September 15, 2020 Report Share Posted September 15, 2020 Check the impedance on the speaker’s voice coil terminal with a dmm. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
BassMunky Posted September 15, 2020 Author Report Share Posted September 15, 2020 11 hours ago, 1point21gigawatts said: Check the impedance on the speaker’s voice coil. wat is it supposed to be Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
1point21gigawatts Posted September 15, 2020 Report Share Posted September 15, 2020 A speaker is suppose to read whatever ohm load the speaker claims to be or close to that number. If it’s reading a high number the the speaker’s voice coil is about to go bad. If it’s not reading at all, then the speaker’s voice coil is bad. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
BassMunky Posted September 16, 2020 Author Report Share Posted September 16, 2020 11 hours ago, 1point21gigawatts said: A speaker is suppose to read whatever ohm load the speaker claims to be or close to that number. If it’s reading a high number the the speaker’s voice coil is about to go bad. If it’s not reading at all, then the speaker’s voice coil is bad. Ok will try and let you guy know.. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted September 24, 2020 Author Report Share Posted September 24, 2020 Soo yeah both blown. How long they usually last? Mine was a little over a year Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
