Box recommendations
Jake220
Here's another option
https://www.sonicelectronix.com/item-136319-Atrend-12RPD.html
It doesn't look as good but it's tuned a little lower if that's what you're after. Set your subsonic to 24-25hz with this one. If you're up for building a box you can do better, the second box I linked appears to not have much port area, that's the kind of issue you run into with prefabs
that's a link to the first one I seen, there's others already here on the site. You just need to find one that'll fit into your trunk. If you're looking for a quick fix to get going now though, either of the prefabs I linked should work. The second one may have some port noise but you have a trunk that'll muffle it so that shouldn't matter. Another I just found that I really like for the price is this one:
https://www.skaraudio.com/products/sk2x12v-dual-12-inch-ported-subwoofer-enclosure-box
With the slight angle on the back it'll limit wasted space if you rear fire it. If you go prefab, I say choose that one. You'll set your amp's subsonic to 24hz with the Skar box.
  • Who's Online   0 Members, 0 Anonymous, 193 Guests (See full list)
