josephj86 Posted November 4, 2020 Report Share Posted November 4, 2020 I've been looking everywhere and can't find a fuse rating for this amp? Anybody? Any input would be much appreciated thanks guys Link to comment Share on other sites More sharing options...
Dafaseles Posted November 4, 2020 Report Share Posted November 4, 2020 600 amp 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
josephj86 Posted November 4, 2020 Author Report Share Posted November 4, 2020 Ok thats cool another thing is I've seen it on the dyno put out 7977rms will this pop the fuses if I fused @600amp? I'm just trying to make sure nothing goes wrong Link to comment Share on other sites More sharing options...
josephj86 Posted November 4, 2020 Author Report Share Posted November 4, 2020 Thanks dafaseles Link to comment Share on other sites More sharing options...
josephj86 Posted November 4, 2020 Author Report Share Posted November 4, 2020 Oh and another run ive seen the amp do 9027 rms @ 1ohm uncertified run to clippin will this be a problem if im fused @ 600amp Link to comment Share on other sites More sharing options...
Dafaseles Posted November 4, 2020 Report Share Posted November 4, 2020 3 minutes ago, josephj86 said: Ok thats cool another thing is I've seen it on the dyno put out 7977rms will this pop the fuses if I fused @600amp? I'm just trying to make sure nothing goes wrong No, it shouldn't. I'm sure that video you saw, they had it fired with 600 amps as well. The cool thing about the SALT amps is the salt stands for Sundown Audio Low voltage Technology. They don't use as much power as other amplifiers that state the same rms. That's why I got 2 SALT 4's for my build! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Dafaseles Posted November 4, 2020 Report Share Posted November 4, 2020 3 minutes ago, josephj86 said: Oh and another run ive seen the amp do 9027 rms @ 1ohm uncertified run to clippin will this be a problem if im fused @ 600amp Also, take into account, I'm assuming you're referring to the Sundown Unofficial videos, they used the the single 1/0 input to dual 1/0 input in they're amplifier inputs. It does help with the current draw and output. Not a whole hell of a lot, but it does matter 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
josephj86 Posted November 4, 2020 Author Report Share Posted November 4, 2020 Awesome man this is some good information thank you Link to comment Share on other sites More sharing options...
josephj86 Posted November 4, 2020 Author Report Share Posted November 4, 2020 And yes it was from the sundown unofficial channel Link to comment Share on other sites More sharing options...
Dafaseles Posted November 4, 2020 Report Share Posted November 4, 2020 5 minutes ago, josephj86 said: Awesome man this is some good information thank you Yessir! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
