DizzleDizzle Posted January 16, 2021 Author Report Share Posted January 16, 2021 So I got my 4 pvc and I'm ready to flare it and finish up sub enclosure. I have a couple questions. 1. How important is it to flare the port ends? 2. How do I calculate port length including flared end sections? 3. How much space do I need between the ports and enclosure walls? Does it matter as long as it doesn't touch? I have to make the ports 12" long and box is only 14 inches deep. So excluding wall thickness that leaves me maybe a 1.25" clearance. Thats before flared ends are added. Unless I include the flares in 12" total length. Here's a couple pics so you get the idea. Some are missing so I'll add more tomorrow dont know why I didnt get any of the front. Link to comment Share on other sites More sharing options...
DizzleDizzle Posted January 19, 2021 Author Report Share Posted January 19, 2021 Got the ports made and flared didnt like the flares so redid them. I'll update one more time when enclosure is finished. Link to comment Share on other sites More sharing options...
DizzleDizzle Posted January 21, 2021 Author Report Share Posted January 21, 2021 So im pretty sure I'm mainly talking to myself at this point but if anyone knowledgeable sees this I could use some advice. So I made the ports at 12" including the flares, I did not make them any bigger because they were so close to the back wall of enclosure. I read a post that said the port needs to be atleast the diameter of the tube away from the back wall or else it will affect tuning(lower). I am confused as this is the recommended enclosure design from manufacturer. Even though I am sure this box will sound great there is too much iffy shit going on here. What should I do go ahead and use it and figure out tuning after or build a new enclosure? Also I will be overpowering the subs eventually and did not account for this when designing and building enclosure. Please advise. Link to comment Share on other sites More sharing options...
