XplosiveAudio Posted January 11, 2021 Report Share Posted January 11, 2021 Hi SMD Forum. I am a long time lurker first time poster! So here's the deal, I'm currently working on building out a Mazdaspeed 6 that i recently acquired at auction. My current equipment is in my signature and i know, its a mess. Basically the trunk is set for equipment as the only things i carry for work are a small tool box and customer purchased equipment. I have a cut out of peg board on the back wall of the trunk for my amps. What im shooting for is a box for maximum SPL but also SQ for 2 Skar ZVX-8" (maybe 3, havnt decided if i want to purchase the 3rd one yet). ANYWAY I am good with woodworking and have all of the required tools so im looking to see if anyone out there can make me plans for the perfect box blueprint/plans for my application. I am willing to pay via Paypal, Cash app or other available option. Please let me know if this is against the rules, if it is i apologize in advanmce. Sub Specs: 8-inch Dual 2 Ohm Voice Coil Configuration Peak Power: 1,100 Watts RMS Power: 900 Watts Competition Grade Pressed Paper Cone Stitched High Roll Foam Surround Massive Triple-Stacked Magnet 2.5" High Temperature Copper Voice Coil Motor Weight: 156 oz Frequency Response: 40 - 500 Hz Sensitivity: 80.4 dB Fs: 41.8 Hz Re: Dual 2 Ω Qms: 3.60 Qes: 1.25 Qts: 0.76 Mms: 132.0 gr Nref: 0.07% Cms: 0.02 mm/N Bl: 15.5 n/a Vas: 14.2 L Sd: 188.0 cm² Xmax: 14 mm RECOMMENDED ENCLOSURE SPECIFICATIONS Recommended Sealed Volume: 0.65 ft³ Recommended Ported Volume: 1.25 ft³ Recommended Port Area: 14.45 in² Recommended Tuning Frequency: 36 Hz Enclosure recommendations above do not include subwoofer, bracing, and port displacement SUBWOOFER MEASUREMENTS Cut-out Diameter 7.50" Mounting Depth 6.50" Total Height 7.63" Outside Diameter 8.65" Magnet Diameter 6.50" Current build: (I know, its a mess) Factory HU - MiniDSP6x8 - AD Designs 6.5" components - DB Drive WDX 400.4 - DB Drive WDX 2k - 12" Rockford T0 - Pre-fab 12" ported box Https://caraudiotx.com/ Link to comment Share on other sites More sharing options...
deafboncemarquis Posted January 16, 2021 Report Share Posted January 16, 2021 i can help you out bud here's some of my work Link to comment Share on other sites More sharing options...
