Little help AudioControl LC2 and gain
Fiesta_glad
Hello guys !
Well my setup is  on Fiesta with stock HU , audiocontrol LC2 , and ampire 2channel with underseat 8" and  gladen front speakers RSX 165 ..... so what I did so far ,find with oscilloscope my max HU signal (before distort) I did that with test tone 40hz , 1khz --- 0 db . After that with these thest tones I plug the speaker wires into LC2 and from output with my DMM I measured 6v gain on both main and bass . I did that because amplifier has input sensitivity 0.1 - 6v . After that I set gains in amplifier Full ranger crossover  with oscilloscope unit I saw clipping. The test tones that I used is 1khz -5db mid/ highs and 40khz -10db . Have I done something wrong from begging until the end of settings ?
How bad was the clipping?
When you add an overlap, that is you actually introducing an acceptable amount if clipping (nothing more than your speakers can easily overcome within lulls of the song). So if it where a little clipping, that's normal
